cmhardwick wrote:ANT doesn't let you scan the UPC in? when adding LOTS of DVDs to the database at one time, this is a must in my opinion, then you can rip them at a more liesurely pace
lar282 wrote:cmhardwick wrote:Now, another question that I'm not sure if it has been answered. I don't remember seeing it in this thread. Can you still use and update the prior version, or are they forcing you to upgrade? I can't try this myself as my main computer is down current (MB Died) and that's where my profiler program is loaded.
I use the old version with the import utility and it still works great. I read somewhere on dvdprofilers site that they WILL force people to upgrade soon. Thta's kind of why I am trying to get the author of the utility to make it work with 3.02
regards
dalanik wrote:lar282 wrote:dalanik wrote:...or you can use AMC, which is free
D.
Where do I get it?
Can I import THAT database into XL?
You can get AMC (Ant Movie Catalog) for free from:
http://www.antp.be/software/moviecatalog/
And there should also be xANT plugin which imports AMC data into XLobby, try finding it from the master list of plugins:
http://www.xlobby.com/files/Marbles_00/Xlobby_Plugin_List.htm
D.
lar282 wrote:I would happily switch IF I can import my dvdprofiler list into AMC. It is NOT fun to add 200 dvd manually AGAIN. Do u know if its possible?
lar282 wrote:Russell wrote:lar282, can you post the steps please.
Will tonite if u want
