Cyberlink remote
Cyberlink remote
Postby Bigmaz on Mon Jan 15, 2007 9:24 am
I have a Cyberlink remote that i bought a while ago with Power Cinema on eBay. I want to be able to use the remote with Xlobby, is it compatible with Xlobby? If it is, then how do i set it up?
Bigmaz
Postby Bigmaz on Tue Jan 16, 2007 10:01 am
Hi guys, anyone able to help with this? The IR plugin tab looks complicated on the F2 setup in Xlobby, i dont know where to start :oops:
Cheers
Bigmaz
Postby bmblank on Tue Jan 16, 2007 1:22 pm
There isn't really any usbuirt documentation yet, but there are some explanations on the post here:
http://www.xlobby.com/forum/viewtopic.php?t=5286
There are a fair amount of posts on the USBUIRT if you search the forums for that keyword.
bmblank
Postby S Pittaway on Thu Jan 18, 2007 8:35 am
i would guess you cant use it direclty with xlobby...
but have a look at girder amd see if it works via that.
