Hi.
If you wanted to have quick access to your xlobby with a wifi remote control.
Lets say in the case that you had it as a source for a centralized music system.
I am assuming that you would need a wifi windows based pocket PC or at least something that had wifi and web access to access the web based admin screen for the Xlobby?
Are there any recommended makes or models PDA or pocketPC that are generally used for this that are reasonable priced?
If anyone could please let me know, I would sure appreciate it.
Thanks for your help.
