galileo2000 wrote:As promised, list of commands for 777:
PLAY:
d:\777\sony_cx777es COM1 18
Menu:
d:\777\sony_cx777es COM1 27
Power ON:
d:\777\sony_cx777es COM1 35 1
Power OFF
d:\777\sony_cx777es COM1 35 0
Top Menu:
d:\777\sony_cx777es COM1 26
Pause:
d:\777\sony_cx777es COM1 19
STOP:
d:\777\sony_cx777es COM1 20
Of course you need to replace "d:\777" with your path.
In order to use those from Xlobby, you need to create buttons and assign events. Or just make batch files and doble-click to execute.
Good luck.
1) Create all your .bat files (see above)
2) Create events to assign the .bat files too, press your F2 button ,select the events group.
3) Add an event named play777 under the movie group.
4) Under the play777 event you just created add the os:execute command from the XL command menu.
5) Add your .bat file, make sure you run a "hidden" window type.
6) Exit setup window
7) Enter skinning window by pressing pause/break.
8.) Assign the new event "play777" to the new or existing button that you are creating or modifying.
9) Exit skin mode
10) Press new button and the 777es should start to play.
Have fun!!!
