Anyways, I didn't use v3 till now, since I got bored with tweaking my HTPC and anyways everything worked with last free version
You can imagine how I feel after I movet to v3... I maneged to make a lot of stuff work but still have a lot of issues.
* Pictures category works OK, but when I click (press enter) on picture/item, it does nothing. With previous version it displayed the pic fullscreen without any event etc. Any ideas how to fix this?
* how do I play movies/videos using internal player? I mostly use avi. Now I use old version of Zoom Player but would prefer internal if possible. What do I have to do to play a movie?
* xAnt plugin doesn't seem to create DB which works OK, I mean DB is OK but there is no coverart. There already is topic on this, but no solution. When I open DB and select an item, and go to coverart, and just add space and then delete it (or make any change in path/name and reverse it), cover art appears. This looks like a bug in Xlobby.
This should be enough for now
cheers,
D.
