Can you import INTO Dvd Profiler?
Postby 90c4 on Tue May 10, 2005 1:31 pm
I've been happily using XLobby for years and haven't spent much time on the forum, which I guess is testament to how stable my copies are. I want to email a list of my titles to a friend and I assume the best way to do this is with DVD Profiler, which I've never used. I have 300 movies on my drives - would I need to type the names of each one into DVD profiler, or is there some type of import that would get the names from XLobby (or from my hard drives - mostly VIDEO_TS but also ISOs)? Is it possible to generate the list without prfiler?
90c4
Postby lar282 on Fri May 13, 2005 7:14 am
no u cannot. Not without somebody writing a import app for u.
do u want a list with only text or a html with coverart and stuff?
wrote a conversion app.
Postby lar282 on Sun May 15, 2005 6:42 am
I thought I could use it to so I started out writing a XML to HTML conversion util for Xlobby databse
Put movies.xml in the same directory as the EXE file and it will create a index.html in the c:\MyMovies directory.
Download at
http://hem.passagen.se/lar282/temp/
check out how it looks
http://hem.passagen.se/lar282/MyMovies/ ... index.html
Postby AirPost on Wed May 18, 2005 7:11 am
Blistering Barnacles !!! Lasse, where did you get those Tintin movies? I'm a huge fan.
AirPost
Postby lar282 on Wed May 18, 2005 7:12 am
internet is a lovely thing
