by jimgarrard on Sat Oct 14, 2006 2:50 am
how do you insert a screen pic in your post?
any way its not that page. the IR is working fine when tested on that page. Its the event page giving me fits. i test the "IR alias/command on the right side and all works fine i then add that command to a event "left side" i then test it "test button on left" and it will not work.
