rhinoman wrote:The other option is to just use a vga splitter, I have a dual output card, 1 into the kvm, the other to a 4way splitter, currently running three touchscreens.
unfortunately that doesnt directly work for my application... cause machinists panel's native resolution is higher than maxium resolution touchscreen accepts(1024*768), if i insert that to projectionist panel... picture gets unworkable blurry. Also i prefer to have different screens on them so machinist for example sees and can access directly the winamps which are controllable from xlobby via touchscreen, and also do other tweaks for OS while xl is running all the time.
However, i plan sooner or later to install another toucscreen(s) to wall(s), cause lets face it small touchscreen on my case has only limited usability... and for that ill be using your suggestion, to have same xlobby run on both (or all) touchscreens.
BTW problem still remains, i was working on it whole yesterday, I got picture on all 4 screens but unfortunately other cards resolution or atleast color depth always remains f?ckd up, which one depends on which drivers i installed last, seems like serb and albanian go together much better than ATI and nVidia... i also have powerstrip installed.... but i m not that familiar with the program... could it help me somehow?
