I'm using a heavily modified Heavy Metal skin as an audio frontend and only want to use a remote for input. I'm bringing up an overlay menu (Load, Rename, Delete) on click from the screen_2.jpg (Saved Playlists) category and can't figure out how to get it to control the selected playlist below.
I've downloaded all the skins I could find to see if someone got this to work, but none had this particular configuration to work with saved playlists.
Is this even possible and if so, any suggestions on how to set it up?
