Hi,
Is it possible to say use a Move skin, and have it be able to select between different Movie databases. (Not using Genre etc)
So what I want to do is Open a Movie page, and select between
1/ Movies.xml
2/ Movies on Kidz Pc.xml
3/ Movies on OtherPC.xml
if I select No 2 I only get to see movies in the Movies on Kidz Pc.xml database etc
If I can, how do I set it up ?
I'm using a self customised version of Jowaldo's Skin
Thanks (In Advance )
Myth
