by edgley on Sat Apr 02, 2005 11:20 am
no prob.
a category is what displays information from a databse on a page of your skin.
goto the page you want to add the category to.
hit pause/break
goto the screen tab >add
type radio into the category blank, and hit add
a dotted green line box will then appear on the page
then go item>category
make sure you have clicked on the green box to select it
now link the category to the music database by selecting database in the middle, and then selecting radio (if that is the name of your radio database)
the stations should then appear in the green box
go to the layout tab to change the appearance of it.
thats the basics, the power of xl comes from how you then use it!
let us know how u get on....
