WannaTheater wrote:Thanks for the replys:
So jji666, do you ever have problems with the thin client locking up?
And muzz, can you explain how you are running XLobby as a fat client? Are you remote desktoping into server machine and running XLobby client application (where XLobby is already running as a server)?
The reason I ask is because I am torn between trying to get a solution to work with an Airpanel, or go straight with wired VGA touchscreen. Airpanels seem to be easy to come by, but I am pretty sure the majority of batteries will have already lived past there useful life, and I haven't been able to find any replacement batteries for these. So if I go that route, I want to be sure it will work well.
thanks!
Hi jji666, I'm in the same boat, I have one Airpanel but would like to also run 2 wired touchscreens. Here is how I plan to do it...
My LCD displays around my house & my projector all come from the main VGA out from my PC on user "Main". This runs TVedia and I control it via a RF remote (ATI Remote Wonder Plus). The Airpanel is connected into the same PC via the multiple user RDP hack, on user "Mediaserver" it runs XLobby fat client at 800x600. Xlobby does all my video switching, audio switching and volume control of my Russound CAV system, ir control of devices (Cable Box, DAB Tuner) and audio playback / IP radio from Winamp, all movie stuff is done through TVedia with the RF remote (much like Windows Media Center)
If I put the main VGA out of the PC on extended desktop (user "main"), I can put TVedia on the main output, and a copy of XLobby on the second screen. This second output works as a touchscreen when connected to one wired ELO. I'm waiting on a second one arriving to see if two work off the same VGA feed, but having used ELO touchscreens before I'm quite confident they will work, as long as they are on different COM ports
Now the only thing is I was thinking was that I will need a second copy of XLobby to run the second touchscreen, but I would much rather just use a thin clent. However even on the wired touchscreen, the delay is at least a second between pressing a button and it happening, which is even slower than the slow-speed wirelessly connected Airpanel!
