Xlobby over remote desktop
Postby lovingHDTV on Thu Apr 28, 2005 7:38 pm
Can I run Xlobby over remote desktop? When I try to start my server via RDP all I get is a black screen call splash.
thanks,
lovingHDTV
Postby lar282 on Thu Apr 28, 2005 9:25 pm
I use VNC instead when I need to administer my HTPC.Free faster better.....
Postby rubbah on Fri Apr 29, 2005 7:34 am
i'we used remote desktop a few times, no problem
could it be a resolution problem?
rubbah
Postby rhinoman on Fri Apr 29, 2005 7:46 am
I use RDP to manage my xlobby server all the time with no problems. You do need to make sure that the resolution of the RDP session is the same as the xlobby screen resolution.
rhinoman
Postby Naylia on Fri Apr 29, 2005 12:36 pm
I do the same as rhinoman, despite being slightly more limiting than VNC it is already installed so I look at it as one less thing you need to run as a service on your htpc.
Naylia
Postby lovingHDTV on Sat Apr 30, 2005 7:22 pm
Setting the resoltion the same fixed it.
Now I can see everything via RDP.
thanks,
lovingHDTV
