Think I may have just found my problem...thought I'd do a detailed re-read of the instructions
Quote:
[Cdaudio]
input=C:\Program Files\Ant Movie Catalog\Catalogs\cdaudio.amc,audio
output=C:\Program Files\XlobbyFr\databases\cdaudio.xml
images=C:\Program Files\Ant Movie Catalog\Pochettes cdaudio\
sort=$$ITEM_ORIGINALTITLE
template=c:\Program Files\XlobbyFr\plugins\cdaudiotemplate.xml
filters=
cdrom=F:\
on the output line, notice the reference to cdaudio.xml
while...
Code:
oncdaudio Cdaudio F:\
where :
“oncdaudio” is the name of your temporary xml database where the plugin will write the information about your cd
tada...this could be the cause of all my problems...maybe...now I want to go home from work, good thing i'm working a short day cause I'm dying to get this working
or are there suppossed to be 2 separate xlobby dbs, one called cdaudio and one called oncdaudio?
