Colby thanks for the feedback...my FLAC files do not contain ID3 tags (although, apparently I could add them...but before I do that, I want to see if I can get the native FLAC tags to work)...
From the "FLAC FAQ"
http://flac.sourceforge.net/faq.html#general__tagging website
What kinds of tags does FLAC support?
FLAC has it's own native tagging system which is identical to that of Vorbis. They are called alternately "FLAC tags" and "Vorbis comments". It is the only tagging system required and guaranteed to be supported by FLAC implementations.
Out of convenience, some plugins and implementations allow and also read other kinds of tags. For example, the official FLAC Winamp and XMMS plugins can also read ID3 v1 and v2 tags in addition to FLAC tags. The reference decoder knows how to skip ID3 tags so that they don't interfere with decoding. But you should not expect any tags beside FLAC tags to be supported in all applications; some implementations may not even be able to decode a FLAC file with ID3 tags.
Is there a way to make Xlobby work with the native "FLAC tags" ie "Vorbis comments"?
thanks,
mv
