Hi,
I'm not sure if this should be in the plugin section as its related to the dvd decrypter plugin. I have only just ventured into the HCPC world and cant wait to get it all up and running, Xlobby looks great i just need to get up the learning curve.
I am having trouble getting the DVD Decrypter working properly, are there any instructions suitable for dummies (ie me), i have read the instructions that come in the readme but dont know how to create a page i.e.
3. Create a page for your skin with. For a minimal example have a look at XLDVDImport.xml
i know its probably very easy but i just dont know how to do it, could someone either point me in the right direction or actually tell me what to do?
When i put a disk in the pop up screen comes up with play, copy or exit. Can i set it up so that when i click copy dvd decrypter starts? any help will be very much appreciated!!!
Jon
