scottw wrote:OK I got the cats working, as always I make things alot more complicated then they are.
Working with the search function now, which is way cool. Only problem I am having is how to you clear the "button>input" on the load of the overlay. If I open my search overlay and type "LED" then search, it closes the overlay and does the search (perfect) but when I reopen the search "LED" is still in the button>input field. I would like to clear that out each time. I know this is simple but must have a "case of the monday's" and figured I would ask.
This turned out to be easier than I thought....
In your open overlay event for the search (or how ever you do it) add the "set input text" event from the xlobby section and leave the text blank - works a treat!!!
