HELP!! skin issues
HELP!! skin issues
Postby ianchandelier on Tue May 03, 2005 4:19 am
hi. am a bit of an ignoramus, so bear with me. had an earlier version of this program (late 2003-early 04) and loved the functionality of that skin. the program became corrupted along with my pc, so we deleted it and downloaded a new (xlobby2pre14) version. love the splashscreen at start, but neither the albums layout nor the navigability of the symbol buttons (old version had words 'play', 'add', 'shuffle', 'play all', etc.).
Is there any way i can get my hands on an older skin such as that one? and can i then customize it so as to keep the new splash?
ianchandelier
Postby rika on Tue May 03, 2005 5:52 am
In xlobby2pre14 you have the same funktions as in old ones.(and a lot more) Its all depending on what skin you are using.
Is this the funktions you are missing in your skin?:
just goto skins and download a skin with the funktions and layout that you like.
Rika
rika
