ok gang after a few sleepless nights i finally figured it out. no command lines are needed open mpc, open device, set all your setting, resolutions, fullscreen, audio, everything you wanna treak, then open the playlist screen add, then save as, i saved it as leadtek this way i can use mpc for mutilple cards with different settings for each, save the playlist in the same folder as your mpc program.then just insert the playlist in the arrguments section when adding as event. set up the button and voila on low memory tv viewing program whoo hoo...ok now i'm gonna go get some sleep....if i can get my wife to help pry me outta this chair ..sheesh
fred
