Is it possible to use a PDA to control Xlobby by using an ad hoc connection ?
Don't want to buy an AP just for this.
I tried it but I can't get XP to communicate with the PDA (or vice versa).
The problem seem to be that the XP machine doesn't bring the wireless adapter up.
So the PDA can't find the network since the XP machine doesn't "up" the adapter (the adapter is configured but it's like you unplug the cable on a normal NW-card).
I can't get Xlobby to use the wifi adapters ip-address either since it's not listed.
Anyone got any ideas, or is the only solution to get an AP ?
