quick skinning category question(s)
Postby defrag on Mon Sep 04, 2006 6:04 pm
Hi all,
When you set a highlight or image for the selected display on a category, it always seems to expand the highlight/image up to the previous/next item in the category. If you have quite a bit of padding between items, then this looks a bit odd. Is there a way to ensure that your selected image stays the same size as the background image for an item?
defrag
Postby Colby on Mon Sep 04, 2006 6:35 pm
recreate your selector image with "naked" (transparent pixels) space around it and save it as a png24.
Postby defrag on Mon Sep 04, 2006 8:58 pm
That did the trick, you gotta be pixel perfect to get that looking right. Worth the effort though.
Thanks Colby
defrag
