I don't understand how a "epg>time" global will help to make a plugin What we need is a possibility to refresh the epg so that it is synchronized with the current time and not the startup time of xlobby
Yes, I know
but how about getting the start and stop time of the selected program, and make change to the page of the epg until you have a selected program that is less than the current time (and that the next page is greater)
that wont work if there is no program in the epg. There will be no programin the EPG if the user has not touched the epg for example 24 hours and there is only 12 hours of epg programs.
The only info there is avalably is epg>time and that is not global so I cannot push that info into a plugin.
Could you use a combination of the EPG>Refresh and then use badubo suggestion of matching the EPG>Time in the epg to the system time. Then move the page forward until the system time is less than the time displayed in the EPG. You say it can not be pushed to a plugin because it is not global, but how about an event?
I can do a plugin IF a EPG program is there and selected. this is not very usfull though
I cannot(maybe somebody else can) do it with epg>time cause I cannot pass it to the plugin code and therefor I cannot page till the correct time is acchived.
this is however really simple for steven to fix like he did with the rest of the epg data. they were not global before but then he fixed that. I also know he has alot going on since I aslo have 2 kids and one of them is only 11 weeks old.
