Just discovered this prog (xlobby2, not the beta) and am anxious to get it up and running. I successfully created the path and imported my music files (which reside on my hard drive), but when I try to create the path to my DivX movies (which are on an external hard drive connected via firewire), I get the following unhandled exception: "object reference not set to an instance of the object."
Am I neglecting to do something first? I have Net 2.0 installed and this has been the only problem so far.
