Thin Client Screen
Thin Client Screen
Postby capecodscot on Tue Apr 18, 2006 1:35 pm
I winder if anyone can help please.
I am running Xlobby on a 10" wireless touchscreen controlling a server. All is working perfectly with the exception of the windows bar being visible at the top of the screen which displays "Xlobby client" and also the close box. Users frequently close out the xlobby interface inadvertantly when waking the panel from sleep mode (and also I do not like to see any reference to Windows).
This does not happen on a ppc.
Any help would be greatly appreciated.
capecodscot
Postby jowaldo on Sat Apr 22, 2006 7:01 am
are you using the latest and greatest exe? just a few days ago I know some were having a similar problem and steven fixed it.
Also what do you have set in your servers.txt for resolution?
Postby capecodscot on Mon Apr 24, 2006 2:18 pm
Thanks for the reply. I'm not sure but I will make sure I use the latest exe.
I have the resolution set to auto. Do you think that this may be the problem?
I am using a highly modified version of Naylia's skin.
It is a shame because otherwise it looks great and functions beautifully on the 10" touchscreen.
Thanks for your help.
capecodscot
