Episode list
Got an idea, post it here
Episode list
Postby senovak on Wed Nov 29, 2006 2:55 am
What I would like to see is a simple list of episodes based on title. So, for instance I could pick a folder of Dora videos then pick one from a list instead of by picture or DVD folder.
senovak
Postby XioPod on Wed Nov 29, 2006 1:16 pm
I think this can already done using the skin editor, but i might be wrong.. (i'm a noob dont flame me :wink: )
I think if you go to that screen in the editor and select the category box (green) you can then select the category tab in the toolbox. once there you'll see a ton of options you can change. look at the layout tab
take a look at this:
http://xlobby.incolby.com/Skinning_Xlobby_3/category.html
XioPod
