MLB TV plug in crashes Xlobby
Postby dhcf23 on Mon Apr 20, 2009 5:05 pm
Does anyone here use MLB TV and the Nextdef plugin for it. It seems the nextdef plugin and Xlobby do not play well together. If I have that plugin running and try to start Xlobby it will not start..errors out. I do not have a screen print of the error right now since I am at work but can get one later if it is needed. Also if Xlobby is already running the plug in will not start. Anyone here use that service and face the same issue?
dhcf23
Re: MLB TV plug in crashes Xlobby
Postby Marbles_00 on Mon Apr 20, 2009 7:09 pm
In Xlobby's splash screen, can you indicate at what spot it errors out? Most skins have a status update while loading the different components/plugins/database that xlobby uses to run. Indicate at what spot xlobby stops.
I'm taking a stab at this since until your post, I've never heard of MLB.TV, but are you running the XLobby XNET server? Could they both be trying to access the same port? If so, then change the port number for your Xlobby server.
Postby dhcf23 on Tue Apr 21, 2009 2:21 am
I did try changing the ports and stopping the server and it still won't load. The splash screen does not start loading anything it is still at the "Please wait..." portion.
Here is what the error says and the details.
Unhandled exception has occurred.....
Only one usage of each socket address (protocol/network address/port) is normally permitted.
System.Net.Sockets.SocketException: Only one usage of each socket address (protocol/network address/port) is normally permitted
at System.Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.Sockets.Socket.Bind(EndPoint localEP)
at System.Net.Sockets.TcpListener.Start(Int32 backlog)
at System.Net.Sockets.TcpListener.Start()
at System.Runtime.Remoting.Channels.ExclusiveTcpListener.Start(Boolean exclusiveAddressUse)
at System.Runtime.Remoting.Channels.Tcp.TcpServerChannel.StartListening(Object data)
at System.Runtime.Remoting.Channels.Tcp.TcpServerChannel.SetupChannel()
at System.Runtime.Remoting.Channels.Tcp.TcpServerChannel..ctor(IDictionary properties, IServerChannelSinkProvider sinkProvider, IAuthorizeRemotingConnection authorizeCallback)
at System.Runtime.Remoting.Channels.Tcp.TcpChannel..ctor(IDictionary properties, IClientChannelSinkProvider clientSinkProvider, IServerChannelSinkProvider serverSinkProvider)
at xlobby2.Control.LoadAll()
at xlobby2.GdiScreenForm.GdiScreenForm_Shown(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnShown(EventArgs e)
at System.Windows.Forms.Form.CallShownEvent()
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
xlobby2
Assembly Version: 1.0.2613.31320
Win32 Version: 1.0.2613.31320
CodeBase: file:///C:/Program%20Files/xlobbytest/xlobby2.exe
System.Drawing
CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
CodeBase: file:///C:/windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
XPluginSDK
Assembly Version: 1.0.2612.4380
Win32 Version: 1.0.2612.4380
CodeBase: file:///C:/Program%20Files/xlobbytest/XPluginSDK.DLL
System.Xml
CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
enabled.
For example:
<configuration>
</configuration>
dhcf23
Postby Marbles_00 on Tue Apr 21, 2009 6:56 am
That's strange because this line:
would indicate exactly that issue.
Or do you have the xReceive plugin installed. Maybe that is trying to use the same port?
Postby dhcf23 on Wed Apr 22, 2009 2:37 pm
No xReceive plugin either, I am pretty much at a loss. So for now I just have to shut down xlobby to watch MLB TV in HD, and then kill the nextdef plugin to restart xlobby. Not a big deal just makes it tougher on the waf!
If anyone has any other ideas on this let me know.
dhcf23
