System.NullReferenceException: Object reference not set to an instance of an object.
at xlobby2.Setup.button4_Click(Object sender, EventArgs e)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
xlobby2
Assembly Version: 1.0.2403.37773
Win32 Version: 1.0.2403.37773
CodeBase: file:///C:/Program%20Files/xlobby/xlobby2.exe
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
XPluginSDK
Assembly Version: 1.0.2378.27802
Win32 Version: 1.0.2378.27802
CodeBase: file:///C:/Program%20Files/xlobby/XPluginSDK.DLL
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
XWeather
Assembly Version: 1.0.2387.38391
Win32 Version: 1.0.2387.38391
CodeBase: file:///C:/Program%20Files/xlobby/plugins/xweather/XWeather.dll
Interop.Shell32
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/xlobby/Interop.Shell32.DLL
System.Management
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Interop.ActiveHomeScriptLib
CodeBase: file:///C:/Program%20Files/xlobby/Interop.ActiveHomeScriptLib.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Design
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
This is the the problem, I have created the database in xlobby format,attempting to import from drive c and/or drive h. Both are generating this error. I am using .net 2.0, winamp 2.95, xlobby 7/31/06.
noobe here still learning, thanks in advance
The EYE
