I am a newb to Xlobby and trying to find information on how to do a multi-zone setup. I am currently looking for an 8 zone setup. I was planning on running the speaker wires directly from main distribution box and amplifying the signal before the signal gets from xlobby PC to the distribution box. Then the drops would run from main box to the speakers. I was planning on using 14 gauge speaker wire. I am going to have runs up to 130 ft.
Would this to be long to run amplified speaker wire? I know it’s not exactly the topic of this forum but I imagine you guys have done this quite a bit.
The next question is that I am looking at how to setup multi-zones in xlobby. I have setup winamp and foobar2000 and tried them both. But when I try to change the wave out sound card config for the first installation it changes it for the second install I have. That's one issue, but I then went under the general screen I just added both foobar and winamp (with different sound card configs) in the zone section and when I went to the multi-zone page its didn’t seem to do anything. I am thinking there is some kind of configuration script I have to make or something like that, but I can't seem to find anything information in the help section or in the forums.
Also I am curious on what is the best sound card to get. I have already purchased the M-Audio 1010LT thinking this would be the best solution but I have read the forums and saw this card had issues with multiple synced play. Through right now, for testing, I am using my onboard sound and an Audigy card I have. Do a lot of other sounds cards have this same issue? Is there one you guys would recommend?
Honestly I don't want to recable my house again. I was originally going to go for a hardware based multi-zone solution where cat 5 terminated at each light switch and speaker wire came from there but I think this solution would be more upgradeable for future use.
So any help here would be greatly appreciated. Or just point me in the right direction where I could find the documentation.
Thanks!
