Sound when pressing button?
Postby anarkizt on Mon Aug 29, 2005 3:19 pm
Hi!
I know it is EXTREMELY annoying to have a sound playing when you press "movies" or "music" but it would be very "star trekkish" so I want it for my skin. Only question - is it possible and how?? :?
anarkizt
Postby rubbah on Mon Aug 29, 2005 7:30 pm
In the sounds folder is where the button sounds are stored. There is one file in this directory called click.wav. This is the sound that plays if button sounds are enabled in Xlobby.
http://xlobby.incolby.com/SkinningXlobbya40.2.htm take a look at this doc by Colby
rubbah
Postby Colby on Mon Aug 29, 2005 11:06 pm
actually this is somewhat changed. There are now sound events which can be edited in the skin editor. You are not limited to the click.wav file as in former Xlobby. Nevertheless, sounds have to be enabled in the setup (f2) menu for your skin to have them.
Postby anarkizt on Tue Aug 30, 2005 6:58 am
Ok, thanks for the info! I'll play oround with it when i get home.
anarkizt
