Cannot run PPC thin client or web server fom PC?
Postby btrcp2000 on Sun Aug 28, 2005 5:01 am
Hi-
NOOB with all capital letters. Xlobby looks like exactly what I've been searching for, so now I need to understand the moving parts.
I cannot connect via the thin client or the web server from my pocketpc via bluetooth, or from another pc on the lan. I have another program that runs a webserver that I am able to access both via the ppc and pc (so it should't be a firewall isue), but xlobby doesn't work.
If i put the address http://xlobbypcip:8001 into IE, I get this:
.NEThServer encountered an internal error. To get more info turn on customErrors in the server's config file.
If i use ports 8000 or 8002, i get a timeout. The thin client program doesn't seem to do anything on either the ppc or pc, and I have doublechecked the ip address in the servers txt file.
Also, I don't see a button on the setup screen to start the webserver.
I know this is probably not enough info, but I'm not sure what else to include. Thanks in advance!
btrcp2000
Postby rhinoman on Mon Aug 29, 2005 7:36 am
The button to start the webserver is in setup/xnet tab which is also where you will find a check box to make xlobby start as a server.
rhinoman
Postby btrcp2000 on Mon Aug 29, 2005 9:25 am
well, so far so good then. I have that all set up, but I have no webserver or thin client. What else can I look at?
btrcp2000
Postby Twit on Mon Aug 29, 2005 5:44 pm
I always have better luck using the IP address.
when you start the web server/xnet server the ip address is listed under status in xlobby - Is it the right IP address?
The web server always works 100% for me!
Later
Simon.
Twit
Postby btrcp2000 on Tue Aug 30, 2005 2:05 am
sorry, should have been more clear. when i typed "xlobbypcip" that was shorthand for my pc's internal ip. i have tried both the numerical ip as well as the pc's name, no luck either way. anything else i can be looking at?
btrcp2000
