I'm new to Xlobby but have been very sucsessful with the Heavy Metal skin and the skin editor to get Xlobby 99.9% customized for my htpc. The only thing I can't get running is the WX plugin. I've read everything till my eyeballs fell out, I think it might be something with enableing the variables. Could someone give me a little help if you got it to work? How do you enable the variables that are on the list in the config page ?
Or any other things to look at, I always get "No data avalable". It seems to find the locations I select in the config page, and will show up in the forcast XML file, but thats it.
Thanks for any advice you could give..
