I'm looking for icons which are a bit like the ones you used.
Arthur
Arthur wrote:Jowaldo, where did you get your button icons? (yeah, I'm modifying your skin, however, it isn't easy as it is very nice as it is) I want to add some buttons on the main menu for Radio, TV-guide, TV, Traffic and train info, Recipies, Babycam (Finaly bought an axis camera, so the HTPC should be able to look after the baby, which is to be born 5th of june, have to have th exlobby thing running by then)
Arthur
jmatienzo wrote:tks for the great skin. Can you make a button on the main screen the says Zoomplayer or DVD Player, that way when you click on it,it plays whatever dvd you have in the dvd-rom, tks.
