Pnadora - how to embed .exe
Postby vaporhat on Tue Jul 29, 2008 3:21 pm
I use Pandora to stream music on the daily and would love to figure out a way to build a plugin into XL or at least incorporate the application into my skin. Is anyone else using Pandora?
Any progress on this?
viewtopic.php?f=14&t=4378&st=0&sk=t&sd=a&hilit=pandora
Re: Pnadora - what's been done?
Postby vaporhat on Wed Jul 30, 2008 3:45 am
How do you embed .exe programs into a skin like this?
Re: Pnadora - how to embed .exe
Postby vaporhat on Thu Jul 31, 2008 2:13 pm
Still trying to figure out how to make an .exe window part of XL.. anyone?
Some added info for anyone else interested:
Pandora Hotkeys
Spacebar Toggle Play / Pause
Right-arrow Skip to the Next Song
+ Like this Song
- Don’t Like this Song
Up-arrow Raise Volume
Down-arrow Lower Volume
Shift + up-arrow Full Volume
Shift + down-arrow Mute
Postby m_ski on Fri Aug 01, 2008 11:23 am
Do a search for xmovewindow on the forum - this will display the window as though it is part of xlobby.
English instructions are at http://xlobby.com/forum/viewtopic.php?f=14&t=5719&p=39482&hilit=xmovewindow+english#p39482
You can also send keyboard shortcuts from xlobby, I think, which will give you the button integration with a skin.
m_ski
Postby vaporhat on Fri Aug 01, 2008 1:00 pm
m_ski, Thank you!
I will give it a shot tonight..
Postby vaporhat on Wed Aug 06, 2008 1:12 am
fyi, the class name for PandorsBox is ThunderRT6FormDC
