BLANK SCREEN WHEN CHANGING SKIN
Postby TONYUK on Tue Sep 13, 2005 8:06 pm
HI CAN YOU HELP ONLY JUST FOUND XLOBBY AND ITS OBVIOUSLY VERY GOOD FOR WHAT I WANT TO DO.
I'VE CHANGED THE SKIN HAVING PUT A NEW ONE IN A NEW FOLDER UNDER THE SKIN FOLDER. I CAN SEE IT WHEN I GO INTO SKINS UNDER F2 WHEN I REFRESH THE SCREEN IT GOES BLACK AND I CANT SEE XLOBBT ANYMORE
CAN ANYONE HELP
TONYUK
Postby lar282 on Tue Sep 13, 2005 8:15 pm
the skin u put in the folder is not in correct directoies. look at the other skin and see whats wrong. it's probably in a subdirectory or something.
to go back to the other skin, just edit the xlobby.xml
lasse
Postby kjheu on Tue Sep 13, 2005 8:16 pm
Does the new skin you're using have a screen chosen to be the start up screen? Have you tried using F2 or Pause/Break when you get the black screen to see if XLobby is still functioning?
kjheu
Postby TONYUK on Tue Sep 13, 2005 8:25 pm
YES F2 IS STILL FUNCTIONAL AND RUNS FINE BUT THE SCREEN IS JUST BLACK.
ITS A SKIN I DOWN LOADED AND IT APPEARS TO WHERE IT SHOULD BE
CONFUSED
TONYUK
