PDA control and IR
PDA control and IR
Postby Chazotta on Tue Nov 25, 2008 11:06 am
G'day fellas.
What is the easiest way (or best way) to be able to control your IR gear (say plasma and preamp) within the Xlobby thin client on a PDA (axim v50)?
Can it all be handeled within XLobby (with plugins etc) or does one need to run other apps, like Girder etc?
cheers
Chazotta
Re: PDA control and IR
Postby Marbles_00 on Tue Nov 25, 2008 1:21 pm
If you have a USB-UIRT, you can do it all within xlobby. I use a UIRT in my music-server. I have it pointed at an AM/FM tuner, and a CD player and can control them both. Then on my PPC I just define the buttons to transmit IR...no problems. The UIRT also has a small jack in the back where you can add (I think) up to four additional transmitters.
Hope this helps.
Postby scottw on Tue Nov 25, 2008 2:08 pm
USB-UIRT is the way to go...best money spent!!!!
Postby Chazotta on Fri Nov 28, 2008 8:03 am
Ok. So I need to buy a USB-UIRT and connect this to the XL PC server right? What is the range? My XL PC is about 6 metres away from the Plasma. The Pre-amp is close to the PC (less than a metre).
Also, how do I learn the Plasma and Pre-amp IR (codes) into XL?
Chazotta
