PPC error
PPC error
Postby sledbc on Sun Sep 19, 2004 1:39 am
Hi, trying to get my PPC connected, wlan is working, set up the settings.txt file as follows
192.168.0.10:ppcmenu
net framework is installed on both machines and the server IS running on that ip.
When i run the client i get the following error:
xlobby2sd.exe
FormatException
Int32::Parse+0xd
Int32::Parse+0x8
Client::SendMessage+0xb4
ClientForm::OnLoad+0x6c
Form::_SetVisibleNotify+0x1d
Control::set_Visible+0x1f
Application::Run+0x7
Control::Main+0x19
any ideas what i should do to correct this?
sledbc
Postby stevenhanna6 on Mon Sep 20, 2004 11:30 pm
woah thats the old way to setup the ppc client.
Get the latest exes here
and read up here on how the servers.txt file should look like
http://www.xlobby.com/Documentation/ClientServer
I am getting some reports that the ppc client isnt working, so check the bugs section if you run into problems.
Postby sledbc on Tue Sep 21, 2004 12:04 am
Thanks steven, i'll try these tonight, i thought i had the latest exe's but i might be wrong.
edit...ohhh since the new exe's didnt put the client files in the client directoy, when i went to set up my ppc i used the old files since they weren't overwritten
sledbc
Postby sledbc on Tue Sep 21, 2004 1:54 am
OK steven, i set it up and it locks up my ppc when trying to load...no error just stops working. I'm using heavy metal skin, should i try default? Also am using ppcmenu in the setup.txt if that matters any.
sledbc
Postby BaddaBing on Tue Sep 21, 2004 3:07 am
I would go try the default skin to test the PPC function. I have not done any work to verify that the PPC skins work in HeavyMetal.
BaddaBing
Postby justonemore on Sat Sep 25, 2004 1:31 pm
I was having a similiar problem last weekend. It was totally my err that was causing it.
I didn't realize that the xlobby2sd.exe and servers.txt files were not supposed to remaim on the machine running xlobby. Just out of curiosity I installed them on the PPC and violla! Once they were both on the PPC (in the same folder) I only had to launch the xlobby2sd.exe and all worked properly.
Not sure if exactly same problem as what you are experiencing, but maybe ........
EDIT......I'm using the default skin.
justonemore
Postby sledbc on Sat Sep 25, 2004 3:49 pm
I got it working last night with the new heavymetal skin.
Its a little slow, but not too bad, it locked up on me once or twice.
Baddabing, if you could label the buttons on the ppc menus that would be awesome. I think you have just about the perfect skin :D If the "anything you want" was PVR and all the music buttons were labelled that would be super.
sledbc
