by jowaldo on Mon Oct 04, 2004 3:39 pm
Its really similar to the show/hide function that a lot of people use on their main menu screens. You basically just do a show/hide image, shape or text, and give it an ID like you would any other show/hide object, but in front of that ID you put a pop-
So the ID for a object that normally was called mainmenu would end up being pop-mainmenu
The pop- just is a flag so if the user doesn't want the pop up tips to show, they can quickly turn them off... even from the skin.
