I'm sure I'm not alone in experiencing this - The XML file generated by the latest DVD Profiler (2.3.1) is subtly different to the previous one (version 2.2.0) such that Xlobby can't read it properly. The key layout looks the same just with extra fields added.
Most of the key database fileds are not read as well as the reference to the stored coverscans.
Is there an option I'm overlooking in Xlobby setup to regain compatibility or will this require a version update?
I've also posted on the Profiler Forum to see if an option to export as per the previous version can be added to return compatibility with the older Xlobby I'm running.
Unfortunately sticking with the older DVD Profiler (2.2.0) is no longer an option as it can't access the online database in order to add new DVDs.
thanks, Phil
