Sorting movies
Sorting movies
Postby lar282 on Fri May 14, 2004 9:00 am
Just wondered if any of u guys sort your movies?
Does it work for u? I'm trying to sort them by collectionNumber, but Xlobby doesn't get it right
it gets the first 1 right, then comes number 10 and then 11 and then random. wierd
Can u guys try it, please
Postby Hiller on Fri May 14, 2004 12:44 pm
Lasse,
Did you create a netmask to have the collection number imported? I didn't think this was done by default. If you are sure your collection numbers are in the database and are correct post to the bugs forum. I think most people just sort alphabetical which is the default.
Steve
Hiller
Postby lar282 on Fri May 14, 2004 12:46 pm
yapp the collectionNumber is in the database. I have it showing on the popupdvd so I know it's there.
Re: Sorting movies
Postby jcruse on Fri May 14, 2004 2:41 pm
lar282 wrote:Hi
Uhh...1, 10, 11 IS the sorted sequence...alphabetically.
Try making your collectionNumbers 001,002,003, etc...
jcruse
Postby lar282 on Fri May 14, 2004 6:40 pm
duhhh. I mean that is what Xlobby sort it as.
my collection is from 1-150
Postby lar282 on Mon Feb 13, 2006 12:55 pm
Use CollectionNumber instaead
