Url is crashing Xlobby
Postby bymyhand on Thu May 24, 2007 8:01 pm
I am trying to insert this url into my roms database and whenever i restart xlobby it crashes. If I take out the & between agg and sql xlobby loads up fine but then of course the site doesn't. I tried quotes but that didn't work. Is there any way I can get around the problem? Here is the url and the crash info.
<url>http://www.allgame.com/cg/agg.dll?p=agg&sql=1:
7501</url>
An error occurred while parsing EntityName. Line 13, position 52
System.Xml.XmlException: An error occurred while parsing EntityName. Line 13, position 52.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
at System.Xml.XmlTextReaderImpl.ParseEntityName()
at System.Xml.XmlTextReaderImpl.ParseEntityReference()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlTextReader.Read()
at System.Xml.XmlReader.ReadString()
at System.Xml.XmlTextReader.ReadString()
at xlobby2.CategoryObject.CatObjectFromXML(XmlReader myReader, Control control)
at xlobby2.CategoryObject.RootFromXML(String file, String name, Control control)
at xlobby2.Control.LoadDatabasesFrom(String dir)
at xlobby2.Control.LoadDatabases()
at xlobby2.Control.LoadAll()
at xlobby2.GdiScreenForm.GdiScreenForm_Shown(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnShown(EventArgs e)
at System.Windows.Forms.Form.CallShownEvent()
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
xlobby2
Assembly Version: 2.0.7131.46
Win32 Version: 2.0.07131.46
CodeBase: file:///C:/Program%20Files/xlobby/xlobby2.exe
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
XPluginSDK
Assembly Version: 1.0.2686.23402
Win32 Version: 1.0.2686.23402
CodeBase: file:///C:/Program%20Files/xlobby/XPluginSDK.DLL
System.Management
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Interop.X10
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/xlobby/Interop.X10.DLL
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
DShowPlayer
Assembly Version: 0.0.0.0
Win32 Version:
CodeBase: file:///C:/Program%20Files/xlobby/DShowPlayer.DLL
msvcm80
Assembly Version: 8.0.50608.0
Win32 Version: 8.00.50727.42
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0de06acd/msvcm80.dll
xlobbydvdcopy
CodeBase: file:///C:/Program%20Files/xlobby/plugins/xlobbydvdcopy.dll
XMpc
Assembly Version: 1.0.1873.2017
Win32 Version: 1.0.1873.2017
CodeBase: file:///C:/Program%20Files/xlobby/plugins/XMpc.dll
XRemote
Assembly Version: 0.2.1966.29535
Win32 Version: 0.2.1966.29535
CodeBase: file:///C:/Program%20Files/xlobby/plugins/XRemote.dll
hbz3lree
0kmuffdq
xusbuirt
Assembly Version: 1.0.1767.29466
Win32 Version: 1.0.1767.29466
CodeBase: file:///C:/Program%20Files/xlobby/plugins/xusbuirt.dll
XEvent
Assembly Version: 1.0.2033.17524
Win32 Version: 1.0.2033.17524
CodeBase: file:///C:/Program%20Files/xlobby/plugins/XEvent/XEvent.dll
XoapWeather
Assembly Version: 1.1.1729.14788
Win32 Version: 1.1.1729.14788
CodeBase: file:///C:/Program%20Files/xlobby/plugins/xoapweather/XoapWeather.dll
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
qkbvhjrq
XWeather
Assembly Version: 1.0.2686.19750
Win32 Version: 1.0.2686.19750
CodeBase: file:///C:/Program%20Files/xlobby/plugins/xweather/XWeather.dll
Interop.Shell32
CodeBase: file:///C:/Program%20Files/xlobby/Interop.Shell32.DLL
enabled.
For example:
<configuration>
</configuration>
bymyhand
Postby bymyhand on Thu May 24, 2007 8:33 pm
Here is the original Url that was in there. This one lets xlobby load just fine but doesn't seem to work on the website any longer.
http://www.allgame.com/cg/agg.dll?p=agg&amp;SQL=GIH
bymyhand
Postby bymyhand on Thu May 24, 2007 9:28 pm
I have fixed the issue. the amp; part of the original I guess tells xlobby to ignore the & sign. But when it opens the site in xlobby it takes out that string. Not sure how it work but it works so cool. :)
bymyhand
