show/hide
show/hide
Postby bkilburn on Fri May 27, 2005 4:12 pm
i like the look of buttons which when highlighted show an image like a music or movie collage. i believe this is achieved by using show/hide in skin editor but after hours of trying how to do it i can't get any of the button images into the show/hide section of the advance tab. i have the buttons ok but can only select them as the main i mage
bkilburn
Postby lar282 on Fri May 27, 2005 8:27 pm
check out Stevens pre release of his skin.He does this.Click the button and enable/disable images.on the image make it hidden.
Postby jovial_mood on Sat May 28, 2005 8:23 pm
If it's only a few buttons you might want to use the naming to change a button's appearence. For example, if the image filename for the not highlighted button is 'filename.png' you name the highlighted image 'filename-enter.png'.
If you're using a lot of buttons or a lot of different images when the buttons are highlighted it might be a better way to use an image database.
jovial_mood
