Here is what I get when I try a F2 manual db load:
\\(?<genre>.*)\\(?<name>.*)\\(?<name>.*)\\video_ts\\video_ts\.ifo
\\(?<name>.*)\\.*\.iso
\\(?<name>.*?)\\.*?
\\(?<name>.*)
Colby wrote:Sharp abob is correct. The reason you are getting zero% is because there is no path to the movies. or are they all offline?
Also does your meta mask match mine? Or does it make a difference?
- Code: Select all
\\(?<name>.*?)\\.*?
\\(?<name>.*)
Good Luck let us know what you find?
sharp_1 wrote:Not sure what happened to my db's but both my movie and shoutcast radio db's must have been corrupt causing them not to reset, refresh or update. I deleted both within XL F2 and created new...everything is back up and running as it should. Thanks for the help!!!
sharp_1 wrote:Still having problem trying to refresh my movie db...I have to delete my movie db everytime I want to update my movie db from dvdpro. Help.
This may be a long standing problem....not sure....I've always had to use hte Delete DB tab then re-import my updated one to get things right. I thought this was just part of the normal flow. I don't have that much time under my belt with XL to know better.
NebrGuy wrote:I hate replying to my own post, but I found baddabing's setup guide at http://www.xlobby.com/forum/viewtopic.php?t=2737. VERY helpful to get things back up and running. Had to clear the cobwebs to remember how to set this up.
