Skin by Ingalls:enjoy!!
Postby ingalls on Fri Sep 17, 2004 9:11 am
ingalls
Postby ingalls on Fri Sep 17, 2004 9:12 am
ingalls
Petit menu quitter avec plein d'otions
ingalls
Postby Aaron on Fri Sep 17, 2004 2:21 pm
the layout is nice.. easy to read, clear, well defined.
adding some fancy buttons would make it great.
Aaron
Postby ingalls on Fri Sep 17, 2004 2:32 pm
Thanks :D
ingalls
Postby AirPost on Sat Sep 18, 2004 1:40 am
Great job Ingalls. I like the main menu - I assume that the numbers are for the remote? Are you using Girder with this so if you press 4 it will go to the music page? If so, can you share your Girder file so I can test it on mine? :lol:
Thanks.
AirPost
Postby ingalls on Sat Sep 18, 2004 11:50 am
It is the one mais by basilou for the skin "matv" from Cmoi, go see in the french forum!!!
ingalls
