Hello,
What I want to do is change the channel on my satellite receiver using my USBUIRT. Basically a PC interface that simulates the remote control for the sat receiver. Will Xlobby by itself do the job, or is Girder also required?
If xlobby can do it, what build supports the USBUIRT? I setup the Alpha39a but I can't figure out how to use the USBUIRT (and how it learns the codes for changing the channel, etc.)
Thanks for any help,
TomD
