display the information recovered by the audio player
Got an idea, post it here
Postby dgemily on Sun Oct 10, 2004 9:42 pm
I posted on support section but I think here is the better place:
What I want to do:
I create a database for my radios, it’s works well but I would like to display the information recovered by the audio player (foobar or winamp) about the song that the radio plays.
If I use playlist.m3u, the information will be displaying but not with the database xml.
I know that if you use the line <type>track</type>Xlobby will understand that the item is an audio file and I will have the possibility to display the information about the item in progress (now playing)But I know only the parameter “track” for this line <type>.
Is there any other line <type> that I can used to make it clear to Xlobby that the items are radio links, in the intention to display the information of the audio player?
Thanks for your help.
dgemily
Postby stevenhanna6 on Wed Oct 27, 2004 1:18 am
Postby dgemily on Thu Oct 28, 2004 10:06 pm
In fact, I realized that you can't show the informations recovered by foobar using playlist.m3u, but you can with winamp...
is it possible to have this option with foobar ?
about my last post, what do I have to do, to show the informations about the actual playing song (on the radio) using a database.xml. (Iwould like to show the same thing that you see when you use playlist.m3u)
do I have to specify a ligne <type>......</type> in my database ?
I tried with those variables :
audioplayer>now>%trackname%
and
audioplayer>now>%artist%
Maybe it's better if you add specifics variables for that fonction, and maybe we will use that possibility with some others applications( not only for the radio)..
Thanks for everything :wink:
Dge
dgemily
Postby stevenhanna6 on Sun Oct 31, 2004 7:22 pm
no I just look for "http://" in the filename and if its http then its a stream so I read the window title. I didnt know it wasnt working for foobar, can you send me your m3u file so I have something to test against.
mailto:steve@xlobby.com
Postby dgemily on Wed Nov 10, 2004 10:42 am
did you find a solution ? I would like to know it in the aim of considering how I will build my database...: do I have to use "http://" link or can use other links files, like pls, asx etc...?
I saw an empty repertory "plugin foobar", Isuppose that is for my request about foobar :D , thanks Steven.
Later,
dgemily
Postby stevenhanna6 on Sat Nov 20, 2004 12:19 am
new foobar plugin that can retrieve the information from the window caption. try it out
http://www.xlobby.com/foobarplugin.zip
Postby dgemily on Sat Nov 20, 2004 12:30 pm
Thanks Steven, it works fine for me Image
dgemily
