iphone touchscreen webserver edition v1
Re: iphone touchscreen skin v1.0 - DOWNLOAD
Postby Jay on Fri Jun 19, 2009 5:01 pm
3.0.9163.26 on Vista.
Postby MrO on Fri Jun 19, 2009 8:08 pm
My event viewer tells me this:
EventType clr20r3, P1 xlobby2.exe, P2 3.0.9166.25, P3 4a36e9ac, P4 windowsbase, P5 3.0.0.0, P6 488f1338, P7 9b, P8 28, P9 system.argumentexception, P10 NIL.
It is a .NET Runtime 2.0 error.
I don't like what my computer is telling me.. :(
MrO
Postby Jay on Fri Jun 19, 2009 9:08 pm
Make sure you have .net 3.5 SP1 framework installed.
Postby MrO on Sat Jun 20, 2009 9:22 am
I received the .Net framework error after I had removed all the old versions of the .net framework and then installed the .net 3.5 SP1 framework.
It seems that .net 2.0 framework is a part of the latest 3.5 SP1 version. So that didn't work either. i have XP SP2 installed. The problem remains also with the latest xlobby_3.0.9170.62.exe. I really don't want to pollute this thread with my problem but it only crashes with this skin.
MrO
Postby Grooby on Sat Jun 20, 2009 9:25 am
The skins fine as far as i can tell and nobody else has reported back so it must be something you have done...sorry for your troubles :(
edit:
I've just done a clean install of latest build of xlobby and out of interest i am downloading the skin i uploaded to see if it opens for you.
Postby Grooby on Sat Jun 20, 2009 10:52 am
Well the skin worked fine...must be something your end :?
Postby Grooby on Sat Jun 20, 2009 3:37 pm
Just noticed one thing, search in music isn't working correctly as i have left the close overlay command on each button. Just remove close overlay from each button event in music search and it will work ok again...oops :?
Postby MrO on Sat Jun 20, 2009 7:35 pm
Thanks Grooby for your effort to help out.
I found the problem. I' just copied all the items of the iphone skin to the default skin by groups untill the crash occurs.
It crashes when i add the musicviewer3.xml and musicviewer.xml.
I just deleted them and now it works just fine.. and i must say..it looks very good.
MrO
Postby Grooby on Sat Jun 20, 2009 10:25 pm
MrO... :D
Postby Grooby on Sun Jun 21, 2009 1:22 pm
Videos of skin added to first post.
Postby wesblack on Tue Jun 23, 2009 5:22 am
Andy,
I noticed in the movie playback controls, Play, Stop, Pause, one or more are tied to CAM1 player so the controls dont work. Just remove the CAM1in the events please. Also I am modifying the lighting menu slightly so we can add descriptions of the individual lighting zones, if you want to do it thats fine.
Excellent Job.... thanks....! your #1
Postby Grooby on Tue Jun 23, 2009 6:01 am
Ok, i'll have a look, i noticed a few things which i have corrected when i made the videos.
I left the lights blank so people could assign what they want to them but if you prefer i will add the zones you have listed in the default.
I will re-upload at the weekend...v1.1
Re: iphone touchscreen skin v1.1 - DOWNLOAD
Postby Grooby on Sat Jun 27, 2009 11:34 am
v1.1 now ready for download...
fixes:
Play, Stop, Pause - movie controls
Multi-zone and playlist changed action on menu animation
Added Xlobby logo to pop up screens
Changed lighting screen to include titles of zones.
Just minor fixes, nothing new.
Postby pietjepuk on Mon Aug 03, 2009 10:31 pm
Hi there,
I too got a problem with the musicviewer.xml, but I solved it!
If debugged with Visual Studio, the Exception states that an image should have a width and height > 0. So I believed it to be an error in one of the images. It turns out, it's not.
For this problem, the term 'internationalization' applies. Indeed, the musicviewer.xml contains a broken number, which in America is done with a decimal . (dot). When using a different locale, such as in Europe, it can be a , (comma).
The solution (or workaround, as I expect this to be a bug in the parser since font sizes do work): open musicviewer.xml in notepad and find the line that says: <spacing>1.75</spacing>. Replace the . with a , then save the file, repeat for musicviewer2 and 3 files, then (re)start Xlobby. Worked for me!
(Alternatively, you can change the language settings in the OS of course)
Hope this helps....
Pietje
PS: This is absolutely the best XLobby skin ever. Many kudos for creating it!
pietjepuk
Postby Grooby on Tue Aug 04, 2009 7:39 am
pietjepuk wrote:PS: This is absolutely the best XLobby skin ever. Many kudos for creating it!
Thanks :D
