I'd like to know if it's possible to have the main screen show the search results as they appear on the PPC screen ... taking mimic that one step further.
I have been careful to use the proper screen naming convention (screenname = xyz, ppcscreenname = ppcxyz) wherever possible. But I think for it to work properly there needs to be "open/close global abc overlay" commands added to the event manager. If I understand how it works correctly this should get the results of the filter search displaying on both the PPC and the main screen attached to the XLobby server.
To be clear, the filtering works perfectly on the Pocket PC OR directly on the XLobby server, but the two do NOT sync at all.
I might not be correct in thinking that adding these 2 events will solve the problem but thought that'd be a good place to start. It seems to work correctly for the open/close global overlay commands, but maybe the open/close abc overlay works differently?
Alternatively, if anyone has this working already, I'd love to hear how you got it to work!
Otherwise, it's up to Steven.
