Have Stills flow down to Sub-Items
Got an idea, post it here
Postby Myth on Wed Oct 19, 2005 10:58 pm
When you have sub-items such as
Friends - Series
Lost - Series
The Simpsons
|->The Simpsons - Series 01
|->The Simpsons - Series 02
     |-> S2e01 - Episode 1 Title
     |-> S2e02 - Episode 2 Title
             |->Plot etc
Any Info in the Parent item, like Plot/ Date/ Actors/ Runtime etc, flows down to any sub-item that does not have that info already specified.
So if "Plot" for the Simpsons is "This is a Strange comedy" then the Plot for S2e02 - Episode 2 will also display this, unless it has been individually set.
This does not seem to follow for the Stills, would it be possible to make it behave the same?
Also as in my previous request (see http://www.xlobby.com/forum/viewtopic.php?t=3614 ) would it also be possible to get stills from Tv.Com
thanks
Myth
Myth
Postby Myth on Sun Oct 23, 2005 12:09 pm
Hmmm I must be the only one that uses sub-items for tv series etc...
:cry:
Myth
Postby Myth on Thu Oct 27, 2005 11:43 am
Dammm still the only one :oops:
Myth
Postby Myth on Fri Nov 04, 2005 7:26 am
Bump :)
Myth
