Hello,
altough I'm newly registrated on this forum I've been using xlobby for quite som time now.
Thanks to all you guys for making it the superb HTPC frontend that is today.
Until recently I've been using the standard database functonality that is included with xlobby. But now i decided to really get orgnized with Ant Movie Catalog and using the xant plugin.
At first sight everything looks great. Database with pictures and everything.
I have a lot of movies that is divided in multiple cd's.
e.g
coolmovie_cd1.avi
coolmovie_cd2.avi
These files are orgnized into a folder named:
m:\coolmovie\
Using the standard xlobby database I could spesify m:\coolmovie\ as the parameter for the movie and zoomplayer would play both avi files in the right order.
When using xant plugin i am unable to do this. In the URL field in Ant I type in m:\coolmovie\. I have also edited the movietemplate.xml so that the parameter does not include any extra quotes.
Checking my movie.xml I'cant seem to find any differences. Between the xml generated by xant and xlobby.
If anyone could help me on this matter it would be great.
Cheers
