thanks ptrinchi for all the help.
I got my X10 working too now.
this Xap stuff is really neat
briands wrote:Is there a newB users guide to setting this up for X10. Any recomended hardware for the X10. Can it receive signals say from a motion detector and respond?
Thanks. If this exists in documentation somewhere, please point the way.
ptrinchi wrote:The new version is actually in test with the Xlobby French team. I will probably post it in the beginning of October.Is this new one done?This version will be a xAP Hub, so you will not need anything else to make working together Xlobby and xAP worldDid I understand it right that I do not need anything else than this plugin. No homeseer, no service running no nothing exept the new plugin with a GUI?
ptrinchi wrote:Thanks for the recommendations Kevin,
I added also functions that allow xlobby to start a list of xAP apps and close the same list on exit for the same reason. Some people wanted to do only simple actions like stopping light before a film (Xlobby with x10 connector).
ptrinchi wrote:I added the hub functionality for those who use xlobby on dedicated computers only. I added also functions that allow xlobby to start a list of xAP apps and close the same list on exit for the same reason. Some people wanted to do only simple actions like stopping light before a film (Xlobby with x10 connector). Even, I agree with you and I think that a separate hub as a service is the best solution. So it starts as a hub server only if no other hub is detected on the computer. Perhaps I will disable this functionality after my tests for the reasons you invoke.
System.FormatException: The xAP message value is malformed
No part of the address value may contain space characters
at KCS.xAP.Framework.Message.xAPAddressBase..ctor(String address)
at KCS.xAP.Framework.Message.xAPTargetAddress..ctor(String target)
at xAPSpace.xAP.Execute(String command)
at xlobby2.Command.Run(Control control)
at xlobby2.Setup.button56_Click(Object sender, EventArgs e)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/winnt/microsoft.net/framework/v1.1.4322/mscorlib.dll
xlobby2
Assembly Version: 1.0.1956.42388
Win32 Version: 1.0.1956.42388
CodeBase: file:///C:/XLobby/xlobby2.exe
System.Drawing
CodeBase: file:///c:/winnt/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
CodeBase: file:///c:/winnt/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/winnt/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
XPluginSDK
Assembly Version: 1.0.1937.25036
Win32 Version: 1.0.1937.25036
CodeBase: file:///C:/XLobby/XPluginSDK.DLL
System.Xml
CodeBase: file:///c:/winnt/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
System.Runtime.Remoting
CodeBase: file:///c:/winnt/assembly/gac/system.runtime.remoting/1.0.5000.0__b77a5c561934e089/system.runtime.remoting.dll
xAP-Xlobby
Assembly Version: 1.0.2018.31551
Win32 Version: 1.0.2018.31551
CodeBase: file:///c:/xlobby/plugins/xap-xlobby/xap-xlobby.dll
xAPMessage
Assembly Version: 1.2.9.6
Win32 Version: 1.2.9.6
CodeBase: file:///C:/XLobby/xAPMessage.DLL
xAPTransport
Assembly Version: 1.2.9.0
Win32 Version: 1.2.9.0
CodeBase: file:///C:/XLobby/xAPTransport.DLL
KCS.Utilities
Assembly Version: 1.1.0.2
Win32 Version: 1.1.0.2
CodeBase: file:///C:/XLobby/KCS.Utilities.DLL
XoapWeather
Assembly Version: 1.1.1729.14788
Win32 Version: 1.1.1729.14788
CodeBase: file:///c:/xlobby/plugins/xoapweather/xoapweather.dll
System.Data
CodeBase: file:///c:/winnt/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
0xhbfnre
Assembly Version: 0.0.0.0
XWeather
Assembly Version: 1.0.1577.33604
Win32 Version: 1.0.1577.33604
CodeBase: file:///c:/xlobby/plugins/xweather/xweather.dll
Interop.Shell32
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/XLobby/Interop.Shell32.DLL
System.Management
CodeBase: file:///c:/winnt/assembly/gac/system.management/1.0.5000.0__b03f5f7f11d50a3a/system.management.dll
AxInterop.SHDocVw
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/XLobby/AxInterop.SHDocVw.DLL
Interop.ActiveHomeScriptLib
CodeBase: file:///C:/XLobby/Interop.ActiveHomeScriptLib.DLL
Accessibility
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/winnt/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
enabled.
For example:
<configuration>
</configuration>
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
xap-header
v=12
hop=1
uid=FFABCD00
class=xAPBSC.cmd
source=PTrinchi.Xlobby.mcs5
target=mcs.mcsXap.*:bedroom.fan
output.state
id=*
state=On
Michael McSharry wrote:
An xAP message was sent and it looks to be of proper form to me
xap-header
v=12
hop=1
uid=FFABCD00
class=xAPBSC.cmd
output.state
id=*
state=On
KCS.xAP.Framework.xAPException: The xAP message value is malformed
mscorlib
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
xlobby2
Assembly Version: 1.0.2098.28537
Win32 Version: 1.0.2098.28537
CodeBase: file:///C:/Storage/Electronics/xlobby2/xlobby2/xlobby2.exe
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
XPluginSDK
Assembly Version: 1.0.2020.31144
Win32 Version: 1.0.2020.31144
CodeBase: file:///C:/Storage/Electronics/xlobby2/xlobby2/XPluginSDK.DLL
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
CodeBase: file:///c:/windows/assembly/gac/system.runtime.remoting/1.0.5000.0__b77a5c561934e089/system.runtime.remoting.dll
CDEX
Assembly Version: 1.0.1685.4787
Win32 Version: 1.0.1685.4787
CodeBase: file:///c:/storage/electronics/xlobby2/xlobby2/plugins/cdex.dll
xusbuirt
Assembly Version: 1.0.1767.29466
Win32 Version: 1.0.1767.29466
CodeBase: file:///c:/storage/electronics/xlobby2/xlobby2/plugins/xusbuirt.dll
xAP-Xlobby
CodeBase: file:///c:/storage/electronics/xlobby2/xlobby2/plugins/xap-xlobby/xap-xlobby.dll
xAPMessage
Assembly Version: 1.2.9.12
Win32 Version: 1.2.9.12
CodeBase: file:///C:/Storage/Electronics/xlobby2/xlobby2/xAPMessage.DLL
xAPTransport
Assembly Version: 1.2.9.2
Win32 Version: 1.2.9.2
CodeBase: file:///C:/Storage/Electronics/xlobby2/xlobby2/xAPTransport.DLL
KCS.Utilities
Assembly Version: 1.1.2.1
Win32 Version: 1.1.2.1
CodeBase: file:///C:/Storage/Electronics/xlobby2/xlobby2/KCS.Utilities.DLL
XoapWeather
CodeBase: file:///c:/storage/electronics/xlobby2/xlobby2/plugins/xoapweather/xoapweather.dll
System.Data
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
2p5ytqf0
XWeather
Assembly Version: 1.0.1855.39961
Win32 Version: 1.0.1855.39961
CodeBase: file:///c:/storage/electronics/xlobby2/xlobby2/plugins/xweather/xweather.dll
Interop.Shell32
CodeBase: file:///C:/Storage/Electronics/xlobby2/xlobby2/Interop.Shell32.DLL
AxInterop.SHDocVw
CodeBase: file:///C:/Storage/Electronics/xlobby2/xlobby2/AxInterop.SHDocVw.DLL
CodeBase: file:///C:/Storage/Electronics/xlobby2/xlobby2/Interop.ActiveHomeScriptLib.DLL
System.Management
CodeBase: file:///c:/windows/assembly/gac/system.management/1.0.5000.0__b03f5f7f11d50a3a/system.management.dll
enabled.
For example:
<configuration>
</configuration>
